Have you tried putting a key in it and opening it ???
….................... On the move
That the front seat out, remove the trim from the pillar. It must have an opening as the seat belt retraction gear is in there.
There may be a way to get to the bolts holding the part to the pillar. Use a sabre saw with a metal blade or cold chisel to cut them off if you can't undo them.
last resort maybe is to take front fender off to get to the hinges and remove bolts then door will come off completley as there is no electricts to the door should be simple enough
there is a thread about replacing door hinges somewhere i think maybe by the ferrett
hope this helps
ps see you at the send off for the boys going north maybe
stephen
Surely you can put a piece of wire down inside the door cavity with a hook
and try and disturb something. I think if you can get your window to work the
door may well open too. Stuff it just burn it lol buy Agatha back
As I said before take it to a Panel Beater.
x2 on the panel beater any good one will advise the cheapest option... might just need to reskin the door.
