Installation as per requirements and zero faults in both installers.
No over voltage or alternator regulator problems guatanteed.
No probs mate, it's all done 100%
under tests it may show 100% but a loose earth strap faulty relay or such might make it play up under working conditions.
After all its a mix and match 4x4, Im doing some shops early next week I'll ask if any have heard of this happening before.
Dying to know what it is, 5 cents or $500 fix
If they are fused (which they should be) then these would be blowing left right and centre with the amount of amps required to melt these things. Even your standard relay would most likely be cactus due to the current draw.
Can we have pics of the fans Andy????
Any developments with this mystery?
