Got a photo of how you mounted it? Interested.
Tip tap tippity tip tappity tap tap ding dong tipsy topsy wopsy mopsy tippy tap tap tipitty wee
I too would like to see how you mounted it.
Tapperty tap 1000 taps for me.
Not the best but,, bullbar is the 4mm TJM Outback ,mounted just at the end of the lhs chassis. on each side there's 2 slotted holes, winch is behind chrome pic. will try for better pic tomorrow
lh pic is from the front, just noticed powder coating flaking off, better fix with powder in a can
Thanks 3dogs you're a champion! I like that idea, might relocate mine out of the engine bay, it's pretty baffled in there. Would be able to put another one in there too!
Heaps of room out the front, plenty of spare holes as options to bolt it to.
I used a different bolt and just ground the head to fit the horn body, easy enough mod IMO
Engine bay would be last place to install it, just make sure horn is pointing down to keep the junk out, you'll be fine
Installed mine today, just put it in the engine bay passenger rear corner, heaps of room there, knocked up a small bracket for it to mount on the rear wall ledge.
Works well, scared the crap out of a couple of my mates with it, haha, good stuff
The 2 x Stebel Nautilas air horns are now fitted. And I've been blasting away, terrorizing the neighbors.
They are real easy to install, with only basic skills required.
Remove the two horns (1 left side, 1 right side)from behind the bumper and bolt in new horns. Wire up both relays, wire up the horns and your done. Next time I won't drink so much before I start. Or drink so much during. 2 hour job took me 5 hours. But I must admit even though I was going at a snails pace, pretty tanked, I did a very neat job of it.
Here is the mounting position of mine on the GQ
Perfect spot
Attachment 20170
Attachment 20171
Looking straight down
Attachment 20172
The Missus says it sounds even more gay with the new horns.
I told a mate I got new horns last, he goes " Yeah let me hear it" so he stood in front of the car and I gave em a blast and he nearly shit himself not expecting them to be that loud.
