Try Jaycar electronics.
They have a good selection of switches.
ACT, Belconnen ph 62535700.
Fyshwick ph 62391801.
cheers
cheers
Thanks but no luck, they have some momentary switches listed on the Web site but not stocked and the same but latching are not the correct size anyway.
Finished the cluster except extending the BA trip meter rod out the facia and doing something with the original nissan hole for the trip reset. Suggestions are welcome. I also need to locate a momentary switch or button that fits the original switch holes.
What about an Aeriel switch it is a two way momentary switch
Have you tried custom rockers on Ebay??
or modifying the blanks to suit
As threedogs said try custom rockers(www.customrockers.com.au), talk to Ian, he can even customise the wording on the switches for a small additional fee.
The switches fit straight in, you just need to remove the bump in the console/dash surround where the switch slots in. Bad description, but you will know what I mean if you get them.
And they are really good to deal with.
Mark
Nice switches. I had a look on the site for momentary jobs but could not see any. I will send him an email and see if he can supply any.
WES components have some in the catalogue but I am not sure if you can order them without an account.
Morning twase,
found this http://www.customrockers.com.au/epag...0%28BLUE%29%22
Ian should be able to supply same switch with custom labels. He can also probably change lens cover as well if you are not happy with blue.
Hope this Helps
Mark
