Pics please Phil!
Pics please Phil!
Finally finished the winch install.
Wired up an in cab controller with isolator switch to the centre console.
Attachment 73151
Tested the flex out over some rocks out Eldorado, scored a fire extinguisher that will make a great air tank , some wanker has dumped about 20 of them in the Park .
Good work mate, pics pretty please & recycling at its best :-)!
Arseholes, some dumping pricks hey :-(
Extinguishers please do be careful though as a lot of gear us blokes buy can run high. ARB twin pumps for example are set @150psi ish and many blokes are running air tools too :-)
Gold then mate :-)! I've got quite a few given to me from CFA retired changeovers etc.. Generally use em as fertiliser pressure packs around the block at low PSI. Should we worry about rust in these old tanks? Mind me there is quite the tolerance down to 150psi from 400psi spec you kindly educate me ;-)
I'll post some pics of the extinguisher tomorrow and the pressure limits and testing figures , I've got to go back out for some wood and I now have to grab another three , son wants two and I'm going to try for a two tank setup.
Extinguisher is roughly 150mm diameter by 350mm high .
@Mc4by, how do you keep that interior clean - never seen a white trim before - is that leather or fabric? Sorry, 1997 GQ perspective coming thru!!
Fabric trim.
Fantasy answer: I make the wife take off all her clothes before she gets back in the vehicle :)
Reality: Canvas seat covers.
