Hey mate when will you post this up? I'm getting the same winch and have the same bar so wouldn't mind a bit of information and details on it. I'll keep an eye on your build thread as its not in there yet
Hey mate, I'm part the way through. Winch cradle itself is mounted - easier enough, just had to rotate the gearbox and install it upside down so that the clutch handle was clear and the rope was feeding out from the top. Still have to get longer bolts to mount the fair lead up properly.
Currently stalled in trying to mount the solenoid, because the winch cradle mounts vertically to the bar the normal mounting points wont work and require you to fabricate up a bracket. Due to the way my bar and grill sit, there is very little clearance to get access to the control box and clutch so its a bit fiddly
Other than that, (which I guess are issues to be expected when buying a lower cost winch designed to fit up to a heap of vehicles and bars), I'm generally impressed with the Runva 11XP!
I might get shot for this as it's not Patrol related! But I bought a snorkel for my Zooki today! Woot!Attachment 52382
a cat battery 650cca for $149 :) not the one i was after as they are short of stock but it will do for now as i can move it to the work van.
Well I've had a bit of a win in the last couple of weeks.
Td and od will like this one
Attachment 52384
It's a soderfors (from what I can make) 131 pound no.3 anvil.
Pick it up from the old workshop which has sadly been sold with the land.
And today picked up a drill and 150mm bench grinder. For $150..
Attachment 52385
Bought a New car today. First New car ever. Hyundai Santa Fe, 2.2TD Bloody Nice Car!!! Stoked.
