Well so far my economy is way down running 98...???
We will see... run a 2nd tank full.
gearbox and transfer case going for $200 in that wrecking thread from a rd30.
good back up to slot some reduction gears in
http://www.nissanpatrol.com.au/forum...008#post520008
Ok I filled up and here are the figures with 98 octane...
I did 367km and needed to put 88lt's in which works out to 23.9782...?
Now I filled up again with 98 octane but only cause the price was at its low point.
Today I rebuilt a clutch booster which went very well thanks to advice from George and the thread on this forum.
I also fitted my old injectors as I have had trouble with the suppliers.. now I set up a rig to run carb cleaner through a syringe and connected to a battery with a momentary switch to flush and clean them.
Had an issue with one injector that was not pulsing but after a quick call to George I was told to give it a tap to get it going... I did the old screw driver held against the injector and could here the good ones ticking but number 4 was not.
Personally I am over it and Mags has told me to pull the pin as she is sick of the fuel bills... I dont blame her as she has been so patient.
See what the next tank of fuel brings....
Mate, my hat comes off to you for having the nerves of steel and patience. If it were me that thing would have been gone a long time ago.
I couldn't agree more on what others have mentioned. Salvage what you can out of that thing financially, and move onto a newer GU of some kind, and hopefully that will sort you out.
I cannot afford 2 car loans plus 2 home loans plus 2 kids ..........??????
I have a small budget to do the td conversion and thats it... or I could just be rid of 4wd's all together for a year or 2 and come back with a decent budget?
Get yourself a nice little Honda Jazz and keep the GQ for weekend carnage!!!!!!!! :driving2:
Completely understandable if finances dictate you next move bud.
Question is if you give the 4wd a break for a while... What if in the mean time you pick up another hobby and never eventuate your 4x4 return! lol
Here's the beginners guide to crochet....bwahahaha : http://crochet.about.com/od/learntoc...-beginners.htm
