New bump stops out of the back of an 80 series cruiser measure 150mm so will still have to pack them a little for safety margin.
Attachment 30152
Attachment 30152
Have you allowed for the compression of the 80 series bumpstops as the compress a heap
my god WOW what an awesome machine. wish i could get mine like that. some good reading here.
Yeah it's a bit tricky Brando, I might jack the car up on the weekend and sit the tyre down onto this bump stop and see how much it compresses before fitting them.
The Amadas are the third set of shocks into the back of this car after destroying the rear shocks twice with no bump stop mod.
The Amadas are expensive and I need to get this right.
Do you know how much they compress?
Put em in a vice or something this should give you something to work from.
Well had a play with the 80 series bump stops and this is what I learned!
They Measure 150mm long.
Attachment 30356
So as you can see I put it on the jack and tried to lift the car with it!!
It compressed........ And Compressed!
Attachment 30357Attachment 30358Attachment 30359
Down to just under 80mm!! The factory rear bump stops measure 70mm!
I need 160mm of protection!
These are being sold all over eBay as a great upgrade for a Nissan! Are they? I dont think so! Bugger it!
You should have known mate...80 serious... down grade more like!!
No rubber mobs down that way that could custom make something up for you???
Maybe not much good to you as they are in Sydney: http://www.nepean-rubber.com.au/ but I'm sure if you rang than with your requirements they could do it. Not sure on cost though been a custom one off job
