PullsyJr
So my GU Patrol is doing the same wobble thing between 80-90kph. I've spent some time trying to figure out if it's the exact speed that causes it or not by driving at a constant speed along a flat road. It appears that it will start at maybe 82kph, but then remain for as long as you're ±8kph. Then it will start up again anywhere in that range. It's weird. If it always started at (say) 82kph then that might be significant, but it seems more to be about setting up the conditions once then always suffering the problem. Maybe I'm just over-analysing the issue.
Anyway, so it's going to a wheel balance on Saturday. As one mechanic said, "start cheap and work up from there." I like the cut of his jib.
I then found the videos that Jack180 linked to, and doing some reading, there are people with dire warnings about taking out the king pin shims. Now I don't want to cause expensive problems to happen in my car so I'm wary (though keen because free is such a great price). Has anyone removed the shims and actually had problems? Or are the warnings just precautionary "worst case" scenarios? 10,000k is good, but how are things after 50-100k or more?
Luke
