also went for a little play up powerlines up near mundaring wa
Attachment 45832
Attachment 45832
Did this rear barn door table today. Will put some photos up of most of the steps. I didnt want to drill into the frame of the barn door so put brackets behind hinges.
Dont really have that many tools so made do with what i have!
Attachment 45848
Just cut the 'u' channel to get the little brackets to go behind the door card
Attachment 45849
Bit of spray paint, the ply had a couple of strips that didnt absorb the paint enough so looks odd at the moment, will try for a fix
Attachment 45850
mounting the hinges to the card before re-attaching to the door.
Attachment 45851
using the brackets at the back with little nuts
Attachment 45852
put them on loosely first to make sure all good
Attachment 45853
tightened everything up with locktite as well, and then cut the screws off a bit so they didnt stick out too much. they fit inbetween the door frame where the cavity has the plastic over it.
Attachment 45854
got the wire trace, heat shrink over the loop, crimped, then heat shrink over the crimp as well, looks pretty tidy
Attachment 45855
attaching the elastic straps to hold the table up
Attachment 45856
again just took the extra length off so it doesnt scratch on the paint of the door frame
Attachment 45857
inside of the door card showing the brackets. they are different lengths to fit into the different spaces
Attachment 45858
counter sunk screws holding the 'u' channel on
Attachment 45859
attaching table to card before re-attaching to the door
Attachment 45860
all construction done. just didnt have long enough screws to put the hooks on for the elastic straps. also need to give it a quick lick of varnish on the top of the ply. leaving the black just the matte black as it blends in well with the original door card
Attachment 45861
Attachment 45862
Attachment 45863
any questions just ask.
Looks good mate
cheers stropp!
well with the table thought i might need some light! $10 for 5 metres off ebay! just wired them up off my rear power panel thats hooked up to aux battery, then ran it across and through the door and up to the brake light. ended up doing two strips so had to cut and solder couple more wires on. so far so good! really lights it up well and not too in your face.
Attachment 46037
Attachment 46038
Attachment 46039
Attachment 46040
