That's different Liftlid , gives.
@ MR seems the 170 deg camera is the go.
think all the ones I have are 130 deg me an idea,
Special bracket just for GUs,,, hmmmmm
Trying to convince myself I need one, maybe one to watch front wheels underneath
and one to watch the winch, I'll wait till someone comes up with the perfect set up,
AArrrggghhhhh
Here is another shot at 6pm when the sun is not so bright
Attachment 33727
That's pretty good I reckon.
Here is with the number plate light on though
Attachment 33728
MR just blow the bulb and put it back in then if you get pulled up just act dumb then you will have no issue, other than the light it looks good:smile:
I mounted mine underneath the far right of the door handle surround on the small rear door.
There is a recess that almost hides the camera, plus the wiring is all hidden and waterproof also.
Evo
http://i984.photobucket.com/albums/a...psb95c1c4e.jpg
I have mine mounted here with a switch to turn it on right next to another switch for the reverse lights on the cage, works brilliant, and can turn on while driving to check on the trailer.
