Plan is to get a couple more mods done and then injectors / tune done.
Brought this one way valve for my Dawes set up
will look heaps better than the OE one Im using now
Fixed a crack in the windscreen with a super cheap kit and it's worked a treat
On the weekend, fitted 4 x 4" ironman foam cell pro shocks, new front sway bar bushes (thanks to Mudski for supplying) and new nuts, bolts & sleeves for the front sway bar links.
Finished installing new speakers in the doors. Went with 6 1/2 inch JVC CS-DR620`s, 50 watt nominal, 300 watt peak. Good match for the standard Clarion head unit. Got them for $45.95 a pair delivered on Ebay. http://www.ebay.com.au/itm/NEW-JVC-C...oAAOSww9VXhEoB These retail in the shops for around $70.00 a pair.
Rear speakers sounded terrible at first, very tinny bass, this was caused by the inner door panel vibrating with the speaker. Fixed the problem by bracing the inner & outer skins with a block of styrofoam. Would recommend these to anyone looking to replace the standard speakers.
Sounds great now, good to be able to listen to some decent tunes on those long trips.
All set now for a new touchscreen head unit (will miss having a cassette player though!)
