Had a browse through the whole thread. Alot of work going on bet it sucks arse having the car of the road for so long. Will be worth the wait though i bet. Not long now either by the looks of it.
Well been doing a bit to the GQ over the last few weeks /months and here is a bit.
So my viscous fan gave up the ghost while playing in the mud a d Nissan want a second mortgage for one so time to rebuild this one.
Took it off, removed the fan and cracked the casing
Attachment 28840Attachment 28841Attachment 28842Attachment 28843Attachment 28844Attachment 28845
So you can see inside that there is a clear silicon oil in there and as I understand it th fan hub needs to be refilled with oil. The right oil!
There is only one place that sells it over the counter and entering the lions den was required!
Attachment 28846Attachment 28847Attachment 28848Attachment 28849
I bought 2 tubes and filled the fan with 1 tube and have refitted it and will see how it goes
I love my twin Thermo Fans :)
Next thing you'll be putting in Toyota bumpstops in the rear end ...
You are now cursed Darren!!!!
Do you know what viscosity that fluid is MR? I can get access to Dow Corning fluid at work which I believe is the same thing.
How do the twin thermos go for cooling? I'd like to convert mine to thermos but have heard most people say that the original fan can't be beaten for airflow.
I have 80s in the front so I might as well ;)
Actually when I put poly bags in the back of dads 80 I collected his bump,stops and they are in the shed and yes they will probably go in. ;)
The upside of that though is that Every Time I hit the bump stops I am smashing on an 80 series!!! He'll yeah! That works!
I have yet to see any proof from anyone that the original fan can't be beaten for airflow from thermo's
Mine does heat up when sitting in long stop start traffic or a hard hill climb but considering I have one core blocked in my radiator and I don't have a decent shroud around my thermo's either, I'm sure there doing there job.
Unlike originals, thermo's keep cooling the radiator down after you switch the motor off and you can switch them off while going through water crossings as well.
I think there is more positives to thermo's than people are lead to believe
