3 Attachment(s)
So here are some interesting facts.
The A Tie Rod on a GU is 1300mm c/c of the tie rod pins. A GQ is 1270mm c/c
Attachment 27666
The Tie rod end on a GU is Longer than a GQ physically and the actual Rod is the same length ;)
Attachment 27667
And the Tie Rod Ends on the Superior 4140 gear come with a Grease Nipple which is nice ;)
Attachment 27668
So can't you just switch tierod ends?? Or are they a different thread??
1 Attachment(s)
Scrap that!
Here is the difference in rod length
Attachment 27669
Bugger I hope I can still use it!!
I see a GU steering box in the future mate to go with your GU drag link and tied rod!!
Can't use the superior one coz the threads aren't long enough!!
Bloody thing mate!! The thread is identical. Just can't get it on!! The GU Rod measures 29.83mm and the superiors measures 30.01mm! It wants to cut and/or clean the thread!! Can't do it!
Drag links are the same length! Different tie rod end taper though.
2 Attachment(s)
2 Attachment(s)
