Not so much a project but another job on the house.
The waste pipe for the pool filter was busted at the concrete slab it was on. So the pipe was re routed, in a dodgy way by the previous owners to another point.
So I managed to reconnect the busy pipe into its original connection in the slab, turned the waste on the pump and water came gushing out from underneath the retaining where the slab is near. So I guess the pipe is busted under the concrete bench the pipe above the concrete being re routed.
So after smashing the conc out with a sledgy, cutting away at the retaining wall I found the leak.
Attachment 85019
You can see the hole in the bend and the 40mm pipe is not even sealed where it goes into larger pipe.
Attachment 85020
