lmfao didnt think of that
Thought I'd buy an infra red heat gun,
http://www.ebay.com.au/itm/NON-CONTA...item1e7acb18d9
Can see it having fun on how hot the coals of a fire are,
how hot tyres get and most important the out side temp of a camp oven
Will let you know how accurate it is
Bought a Scotts Rods 3 inch exhaust today :D
Might have scored a 70 pound compound bow..
Needs a string.
Cost, a 6 pack..
[QUOTE=Westy's Accessories;493480]Might have scored a 70 pound compound bow..
Needs a string.
Nice pick up, all I can say is PM oncedisturbed for an arm guard and never ever dry fire it.
it ruins the bow and makes a mess of your arm,
Just bought a Bosch laser measure good for 100m if you have a steady hand lmao even Bluetooth the figures to my phone its a little ripper 25000 measurements per charge beats a bloody tape measure!
Bottom end main bearings a new high pressure head waterpump vrs kit gasket goo acid diped block rwady for rebuild
I brought a stainless steel bucket for camp, during the day it can keep the shrimp alive,
at meal times it can sit on the fire for washing up water, just need to remove the red plastic handle
And the price $10 norm RRP $18 on ebay plus $8 post so very happy indeed
bought a new head unit and reverse camera can actually see out the back now
Had a little eBay sesh last night..
200 A shunt and gauge
$20
http://www.ebay.com.au/itm/Digital-A...-/331154948008
A volt meter
$2.30
http://www.ebay.com.au/itm/NEW-4-5-3...-/261110214343
And some momentary switches
$5.50 for 10
http://www.ebay.com.au/itm/10-Pcs-Mo...-/271436268363
@ Kallen just brought the same gauge , idea is hopefully it will fit somewhere I can see it,
ATM I have a square one wire into ignition and sit in front on the speedo cluster with d/s tape
Superflex swaybars......:D
Dunno. They are longer and thicker so the effort required to twist them would be similar to stock, I would check the difference between your swaybar on and off and if there is on minor difference in travel I probably wouldnt bother
Had a 30% off voucher from anaconda, so bought a fridge slide
got myself a great underwater torch very impressed with it.
Even has a belt cutter on the side
After years of tangling & untangling air hose I got myself one of these.
$176 delivered (Ebay). 20m of hose & a 2m hose to connect between compressor & reel. There are cheaper (& more expensive) but I like Jamec Pem gear. I have found it very reliable over the years, unlike some of the cheapie stuff.
Well I didn't buy it today it was Monday. But just bought a GQ TD42 SWB Safari :)
Bought a new lil gas cooker at Bunnings, slightly smaller in size and the case is smaller than most but it came with its own hotplate, means i can take the frying pan out of the drawers
Attachment 43195
Bought 2 small fold up alloy tables, use em as kids tables for dinner, then drinks tables for us..
Forgot to mention it, but a while ago, I had a child restraint anchor point fitted to my ute, as that particular model was eligible.
Got it done at Vanquip in Welshpool and they put a modification plate in the engine bay and registered it with the Dept of Transport.
Cost $185, but well worth it - and legal. lol
I bought myself "SLASH". Lol
A small tractor for me block. It is a Kubota L295 with slasher, grader blade, single and double plough and a stick rake.
Its only a 2wd model but it will suit my needs.
Attachment 43209
Fancy ride on mower that one!
bought a compressor..thought for the price may as well have a look and see if it is a throw away
Attachment 43210
[QUOTE=menace 2;498040]bought a compressor..thought for the price may as well have a look and see if it is a throw away
I brought the single headed pump and the thermo cut out half way through the first tyre, hope yours is better,but I have a few.
Brought myself a Ghillie stove, can boil water any time you like very happy,,,,,,,,,,,,
Thaaannks !!!!....lololololololol
http://static.tvgcdn.net/MediaBin/Ga...illbillies.jpg NeK MINNIT!! BWahahahahahahaha
also brought some of these cheap enough to keep a few in different places
