Cheers, I was typing too slow again :-)
@MB
[QUOTE=MudRunnerTD;674199]So I had to drill 14mm holed up into the bottom of the chassis to mount the GU tow bar. I'm pretty stoked with how it's come up.
I wire brushed and painted the towbar before mounting it.
http://www.nissanpatrol.com.au/forum...2016/05/31.jpg
http://www.nissanpatrol.com.au/forum...2016/05/32.jpg
Today I cut off the factory tie down points off the back as they are in the way and not required.
http://www.nissanpatrol.com.au/forum...2016/05/33.jpg
http://www.nissanpatrol.com.au/forum...2016/05/34.jpg
Then I made a start on my new rear bar. I bought some 100mm wide flat plate 16mm thick to use as the mounting plates and will incorporate a recovery point at each chassis rail too.
In between it Pissing down rain today I got a little bit done.
I will make the middle of my new bar the same as my old one with C channel as I like the look.
The mounting plates.
http://www.nissanpatrol.com.au/forum...2016/05/35.jpg
Marked out and centre punched ready to be drilled in steps.
http://www.nissanpatrol.com.au/forum...2016/05/36.jpg
http://www.nissanpatrol.com.au/forum...2016/05/37.jpg
Now the 25mm recovery hole suitable for a shackle. The plate is 16mm thick and I left 25mm of meat in front of the hole. I consulted 3dogs about this and he reckoned that would be fine.
http://www.nissanpatrol.com.au/forum...2016/05/38.jpg
http://www.nissanpatrol.com.au/forum...2016/05/39.jpg
http://www.nissanpatrol.com.au/forum...2016/05/40.jpg
http://www.nissanpatrol.com.au/forum...2016/05/41.jpg
Using a 100mm cutoff wheel I marked where I will grind to later.
http://www.nissanpatrol.com.au/forum...2016/05/42.jpg
http://www.nissanpatrol.com.au/forum...2016/05/43.jpg
I bought this drill bit set off eBay years ago! Bloody handy bit of kit!!!
http://www.nissanpatrol.com.au/forum...2016/05/44.jpg
Did I mention it pissed down most of the day!!
http://www.nissanpatrol.com.au/forum...2016/05/45.jpg
Damn I need a Shed!!!
http://www.nissanpatrol.com.au/forum...2016/05/46.jpg
Mounted up the mounts to the GQ Factory towbar mounting holes.
http://www.nissanpatrol.com.au/forum...2016/05/47.jpg
http://www.nissanpatrol.com.au/forum...2016/05/48.jpg
I'll grind the radius later.
Cut and test fitted the C channel
http://www.nissanpatrol.com.au/forum...2016/05/49.jpg
http://www.nissanpatrol.com.au/forum...2016/05/50.jpg
Measured, marked and drilled the holes for the 4 mounting points across the back where I have previously welded nuts on for my last bar.
http://www.nissanpatrol.com.au/forum...2016/05/51.jpg
I have also decided I will cut the end of the towbar off behind the pin hole and per mantle mount a new hook into the tow bar tube with new longer bolts through from the top like the removable one but permanent.
http://www.nissanpatrol.com.au/forum...2016/05/52.jpg
Getting there.
Sent from my iPhone using Tapatalk cause AB turned it back on!![/QUOTE
Looks good to me, thanks heaps Dazman [emoji106][emoji106]
@MB here are a couple on the car mate. You could do similar but weld onto the top edge for sure mate 100% doable.
http://www.nissanpatrol.com.au/forum...020/08/194.jpg
http://www.nissanpatrol.com.au/forum...020/08/195.jpg
Mark, have a look at this design. This is what I believe addresses the forces and their directions - Vectors they are called. Its a serious structure, however it will do the job, and is what i would build myself. The integrity of the towbar is maintained and in fact is increased as it is now hard locked into the upper chassis member.Attachment 81895Attachment 81896Attachment 81897
I like that a lot thanks Phil Mate!
Ticks all of my concerns too as 17,000lb potentially doubled and angled once I think you said can be some scary sh#t[emoji106][emoji106]
Just in the shed trying to visualise it thanks mates, got me thinking again, is there any structural drawbacks on the OEM chassis back down the line?
An element of chassis rail flexyness is possibly OEM designed in and hoping this wouldn’t lock them together too much?
Only reason I mention is that I met a bloke before lockdown readying his ISUZU twuck for around Australia and he choose a full floating type tray <> chassis mount system to retain some flex he was trying to engineer in.
Cheers!
Roger that thanks heaps mate!
Now.....does Australia Post deliver for BHP these days :-)
