Wise advice Cuppa , to add to that what I've done on the folding panel is a small amount of silastic to stop cords from flexing back and forth into the regulator , just a small dab on the wire and fix to the back of the panel .
I think going just the panel and using the redarc so I can charge off the car as well would be the way to instead of a kit.
Will do @Clunk, be a little while yet, I'm booked in for an overnight CPAP titration sleep test thingo next week. I'll be buying from the US. Cheaper, as I don't have health insurance & the model I want isn't available here. It's a later model Devilbiss which is a bit quieter, uses less power (does that make this on topic?) & runs on a plain, easily replaced 12v lead & has a reasonably small footprint with humidifier attached (about the same as a 2 litre ice cream tub). There are a couple of smaller travel ones but both have 'issues' I wouldn't be happy about. Some of the others can be plugged into 12v, but actually run at 24v so have to incorporate a voltage converter either in the lead or in the machine, so end up drawing quite a lot more battery power. Check out the power specs of the later Devilbiss in their manual. A friend has been using one with the humidifier in his Oka for around a year now & is very happy with it.
You're the 2nd person to mention a 4 week trial. The other person mentioned they had had one & that it was free Nothing about that has been said to me. How do you access it?
75.4 AHI is high. Under 5 is normal & over 30 is considered 'Severe'. Mine was 43.1 with the longest apnea lasting 81 seconds. That's a long time to stop breathing for & my overall oxygen saturation levels was 89%, but dropped as low as 78%. This desaturation was described as 'profound'. A couple of people including one who's daughter is a Resmed engineer, tell me I'm well within brain damage territory!
All seems a tad dramatic but I guess it's better to know & have the opportunity to do something about it than to not know.
I'm in the 3rd week of a 4 week trial, it wasn't free though. Cost was $400 for the 4 weeks and they give you an option to buy the machine off them at a supposed discount at the end. I have private health but of course it didn't cover the machine. It did cover the Private hospital and sleep study though. I just thought the 4 week trial was all part of it. The same mob that did the sleep study does the 4 week thing, so this set my scam detector off a bit!
My Oxygen levels dropped to 73% with an AHI of 44 and was diagnosed with asthma also (Been a long term smoker, but quit 4 months ago), so scary stuff. I've been a bit disappointed that I haven't seen instant results from the CPAP, but my AHI has now dropped to 0.9 so I guess its working? This getting older sucks knobs! The power use doesn't concern me a lot as we rarely camp more than one night in the same place. if need be, I'll throw another battery in to cover the use.
@Cuppa yes it was directed to "Prez"@DXgrunt only as a suggestion.
DXgrunt knows where and what type of driving he intends to do so
mounting them on the pod doors could work for "him". I did not suggest
every Pod owner to mount them on their doors.
They actually make flat , flexible panels these days which I'm assuming can be mounted without the airgap needed for others .
I have had people ask me if I'm worried about the solar panel getting hit by a stone on the front of the GQ , lucky for me god put a stone magnet in the form of a Windshield in front and so far this has been 100% effective .
Ha ha, very good! :D
Based on what I’ve been told by others you need to be careful with what ‘flexible' panels you buy if intending on mounting them to a rigid structure. There have been numerous failures with the ’semi flexible’ thin panels which have an aluminium backing - avoid them like the plague. When they get hot the backing expands at a different rate to the cells mounted on it & destroys the panel’s functionality. Those with a plastic back are reported to be better, although it may still be advisable to mount them onto a layer of corflute or similar rather than direct onto a metal surface.
Fully flexible panels (designed to be unrolled for each use ) are a different product.
Im thinking the "good" flexible panels are better suited to a marine enviroment
Does anyone know the correct way to fit these connectors.
Some Ive fully soldered but that doesn't seem right.
http://www.ebay.com.au/itm/5-x-MC4-S...gAAOSw-zxWnC3A
