bohall, have you gotten an update for us..........????
really want to know
really want to know
He's probably still recovering from last weekend's beer treatment. ;)
Since this post and a full tank of gas it has behaved . How do i post images on here ill put up a photo of my rig and engine bay
oooohhhh
nice and red................
now, you see this here Valve -
Attachment 60343
this controls the amount of Gas going into your Carby
for some strange reason, that I could never work out, whenever the bonnet is open, people like to play with it
twist it in, or out
and then the car runs crappy
when you get it tuned, good idea to put a nice little mark on it and the pipe
so if anyone DOES play with it, at least you can get it back again
now, you see all the connectors, if they look like this -
Attachment 60345
go get your crimping machine, and whole heap of plugs, and replace every one of them
see the end of the copper - and its brownish - dirty - need to clean them - snip the end off, scrape the ends of the wire until its clean, and replace with new plug
with that "flash lube" bottle near the fire wall
sewing machine oil is just as good, and cheaper
The guy i bought her off reckons he didnt use any oil in that container ??? Lol i like the price of gas but im new to all the gear that goes with it
the oil is to help lubricate the upper cylinder, as Gas is dry - so things like Valve stem seals dry out and crack and then oil drops into the cylinders, and you burn it
and then you think your rings are shot
also helps lube the parts of the carby that would normally have liquid petrol running over them - the butterfly's etc
