Fair enough mate.
It needs doing either way.
The coil hats can tear away or bend without bracing when loaded up.
For sure @Wathog1 good man!
Bent braces I’ve personally seen on some of ours, cracking I’ve seen posted here, there is truly outback horror stories out there too :-( !
Boss braces were included in my Pedders GVM upgrade along with rear braced axle. They are a nice bit of gear and very well made.
@PeeBee Ive just purchased the Superior tower bolt on kit, any idea what time frame it would take to fit with out hoist.
Or am I better off getting a shop to fit them
Apologies TD, been away all weekend, just back. Look can't really comment as my Superior kit was a weld in kit and it took me all day because I made a meal of getting the springs out and back in. I would suggest you get yours fitted or find someone with fingers like a praying mantis from what i hear. Are you buying the kit for the individual tower or the kit to tie the towers together?
TD you have a tray don't you if that's the case jack the rear as high as u can and brace it there undo the tray bolts at the rear and take the wheels off the back and lower it down. The object of the excercise is to be able to get in and line the brake line pad up ,so to do this it takes a bit of bending and prying to get the pad in underneath.Tip: leave front tray bolts done up so as to make it easier to line the tray back up.This is for the plate across both towers.Tip: stock fridge.
