Oil and coolant cooling are for the moving parts,
So for the heat in the turbine gasses..... you need fuel to make the heat, you need the heat to make the boost, so in theory, if you can keep in some heat from combustion, you should be able to make the same boost responce with less fuel.
Thats why I have ceramic coated so much in order to somewhat test the theory
