Wastegate actuator fitted.
Attachment 48646
Attachment 48646
Attachment 48647
So how does it work exactly? Spring in the actuator loads the turbo vanes at max and once turbo pressure goes over 18 psi it starts pushing the actuator down to back the vanes off?
How does reinventing the wheel sound?
You could do the same with just the Dawes valve set to bleed vacuum at 18 psi, closing needle valve fully or ditching it completely.
B/R
It's supposedly an actuator with a dawes built in, kind of. I don't know why they opted this over the needle/dawes, but I can tell you now, the car is much better with this, than it ever was with needle/dawes, no matter how much I fine tuned it.
I've just driven the car for about 2 hours after job was done , and it is the best its ever been since ive obtained it. Thats what matters to me.
