Plumy,
The 265 tyre is 20mm wider than stock on a wide wheel kitted patrol from the factory.
In my case the stock tyre rubbed on the chassis rails as posted previously, so going to a slightly wider tyre was going to rub more, possibly doing damage.
The only ROH rim that suited had the -13 offset, that moved the rim out 23mm from stock giving plenty of clearance for it all to fit.
So using a 265 tyre on a 0 offset rim you may find the tyre will touch the chassis when flexing, as you have the rim you might as well use them and see what happens.
Also you will not be exceeding the maximum track allowed by most states from what I can figure out anyway. +25mm wider is the limit?
