good work, so many would have said stuff it and parted it out or swapped running gear over to another. you have done some fine work to get it back to a fairly straightish vehicle again... i hate body work!
good job on the repairs , pita about the roll over but its good to know that you walked away .
Great work mate !
You did a brilliant job on the gaurd holes, shame the gold isn't a bit closer, but the burgundy looks a pretty good match.
Roof is great, does not look like its been rolled, any joy with the rear 1/4 ?
Top efforts so far :clapping:
Good job mate well done NOW DONT DO IT AGAIN!!!
Thanks .. Yeah the burgundy is almost a perfect match. It's a pity the gold is slightly different. At some stage I will do some blending across the door. It's possible that I had the wrong base colour under the gold ... and also 20 years of vehicle colour fading.
I cut the hole in the guard with the Dremel cut-off wheel. Came up quite well, except I stupidly mis-marked one of the measurements ... should have double checked everything before cutting. It didn't matter too much as the indicator assembly fitted okay.
I haven't started on the rear 1/4 yet. I plan to start on that one next week.
