My kids are now old enough to fend for themselves and don't come away with us anymore! Time to rip out the rear seats in my GU and do as AB has done me thinks!
Hi Team,
I'm still playing around with trying to fix the nasty wobbles on my GQ, time is difficult lately.
I'm going to check out King Pin bearings next and I might just replace them anyway.
I'm not overly keen on just removing a shim like some have done.
The question I have is if I replace the bearings with the same brand which I assume would be the Koyo's (need to confirm this when checking them) would you need to bother with removing everything inside and checking the preload or would it be fine to just replace with new and go?
Bear in mind that even if you replace the king pin bearings, you would still need to gauge the tork with an assortment of shims. So, in my humble oppinion, if your current bearings are good (no marks, smooth turning movements) I would really just re-stack the shims accordingly to achieve the manual load.
Thanks mate, I understand the shims and preload so they sit nicely above and below and I understand the shims purpose of machining tolerances of the knuckle in the factory but if they are the exact same brand bearings replaced than surely the bearings are bang on with size and will match the shims already in place to suit?
It could very well be, but honestly, out of coincidence. I wouldn't count on that.
You see, if one bearing race is pressed a little less onto the knuckle seat, the shimming would be different. Bottom line is, shimming is the final adjustment on a king pin by king pin basis.
Eureka!
I finally solved the nasty wobbles.
Just replaced the panhard rod bushes and it now drives like a bloody dream!
They felt fine with no movement but closer inspection showed some wear and they were nolathane too.
Anyways, Its such a pleasure to drive now!!!
Attachment 87584
I made up this little tool today which easily removed and installed the bushes too.
http://www.nissanpatrol.com.au/forum...2023/12/25.jpg
Found a good extrusion that works well with the top radiator today from Clarky.
https://uploads.tapatalk-cdn.com/202...9aff8c8111.jpg
http://www.nissanpatrol.com.au/forum...2023/12/29.jpg
Linky pretty please [emoji120] and or Clarkey code number [emoji182][emoji3590][emoji3590]
Get OFF the Nest/McAnswer @AB [emoji35] [emoji23]
That looks like the Ultimate Rubber Aussie Available ANTI-TD42 McCooking device [emoji736][emoji106][emoji106]
It’s not on their site unfortunately.
You have to visit the shop, give the clerk a wink and tap your nose not once but thrice and say extrusion.
She’ll open a door to the back room, turn left, then right, turn around and ya can’t miss it.
Super Helpful….Cheers & Beers [emoji481][emoji481]
Maybe L x W x H + angle [emoji424] of its dangle [emoji120][emoji120][emoji182][emoji182]
Found it gents…
https://www.clarkrubber.com.au/produ...eal-33x-16-3mm
Installed a water tank today for the GQ, I can’t think of any other way to secure it, thoughts on this way with straps?
Looks ugly but???
The tanks tapered so it sits snug against angled cargo barrier.
http://www.nissanpatrol.com.au/forum.../2024/02/4.jpg
Put some 10ga screws through it :oops:
Make sure to pack/block the sides to stop if sliding left and right mate.
Maybe a piece of 50x50 ally angle like this? Checked out on the sides to screw onto frame, good chunk of foam or soft rubber to stop rubbing.Attachment 87683
.......from under the great down under.
I dont think it will move with the strap, full or empty, everything else is just added weight I reckon, its wedged into the cargo barrier.
In ALL seriousness, and in the somewhat words absorbed of the great NP.com.au…ET @EvilTwin [emoji120][emoji120]
‘Throw a brick at him, if he ducks great’ [emoji23]
Usage……= Family Tourer (Flat Roads)
Usage……= Shenanigans (Upside Down Potential)
Build for ALL Scenarios [emoji120][emoji120][emoji3590][emoji3590]
