DW i should be right, theres nothing better then a challenge, just need to take it nice and slow mate. No need for heroics and i'm sure with all your experience and guidance even a blind man could drive thru with ease!
If you plan to do any of the harder tracks we ask that you have rated recovery points or risk damage if you get stuck and you have to be recovered.
The rear is not so much of an issue as long as you have a tow set up as many of us have removable hitch points we can use on other cars but the front is a different story??
It is not up to me to explain rated recovery points but the onus is on the driver to know what is expected at a minimum .
I remind you all that this is not a club run but a meet up of a few mates going for a drive and any damaged suffered is off your own back.
And last we are here to have fun in a safe way!!!!!!!!
Both, if you pull the car from one side you risk twisting the chassis and this does happen.
No dramas i'll get stuck into it then!!
Good stuff George.
Thanks Chris! Hopefully i have made my exhaust by then as well.
There's a fire burning around donnely's creek area ATM. Thought I'd post it up y not
Thanks for that see brlow
http://www.cfa.vic.gov.au/warnings-r...265227895.html
