Hopefully wire up some lights on my roof rack.
Weather permitting
Weather permitting
Wired up my roof lightbar...BRIGHT.....and found two Hercules 8000 lb snatch straps in my Recovery gear to return to 4wd Supacentre. Has anyone else returned yours? Did you get a replacement? I have to send mine from Adelaide.
Installed my adjustable draglink, went down the road to get wheel alignment but they too busy:(
Fitted a new section of vacuum hose from the brake vacuum tank to the metal pipe after removing the old piece with a "tee" fitting that used to power the old cruise control now upgraded with a new unit.
new springs and shocks, some of the dynamatting is done
Gave it some fresh Delo oil, a couple of filters, fuel filter and air filter. It'll get a grease tomorrow.
