Hi guys i'm chasing a 33" tyre to use as a spare, the other 4 are bighorns so one of them would be great. So if anyone nearby would have one they want to part with. Preferably a mud tyre. I'm located in Castlemaine Vic
What size rim?
Mic
Sorry i should have said. 15" rim.
WTB: 275/70/16 or 265/75/16 tyres MELB. Let me know what you got. Must be roadworthy
I've only got 16"s or 17"s.
Sorry no can do from my end, but there should be plenty of others with 15"s.
Mic
in melbourne mate, think i have fixed mine for now but i will get back to you and let you know if i need one.
Ok
Sent from my HTC Desire HD A9191 using Tapatalk 2
Hey guys
Looking for a spare 305 70 r16.
any tread depth, any brand, just need a spare
Just thought i would throw this out there, I have a complete loom for a td42 1990 model, the belhousing needed for a diesel the starter motor and all the fuel lines and filter mounts for in the engine bay, the correct dash cluster for the engine aswell. a couple years back i toyed with the idea of putting a turbo diesel in my 1988 gq wags, i actually talked myself out of it due to loving the sound of the tb42 and the fact that i couln't really be bothered taking on another project at the time, mind you the diesel would have been a better option, i sold the engine for $2500.00 the car it came in only cost me $1000.00. long story short i need a tb42e computer, loom, coil, fuel pressure reg and all the relays and modules for the panel next to battery.
let me know if anyone is keen on swaps
i have rear sway bar, dickie seat and power steering pump. the dickie seat is old trim pattern from my 1988 wags the rear sway bar is factory disconect type an needs new joints, im sure its the same as a standard type. the pump is sitting on my spare engine. i am located in port augusta south australia
Postage on that stuff to Brisbane would be more than what the items are worth. Thankyou for the offer, but looking for something a little closer to home.
i want to change my airfilter on 1999 GU and fit the Filter that fits in the Turbo and later model patrols. complete with all hoses will be good. can send me email abendean@connect.com.fj will arrange pick up / freight
285x75x16 is far more common and same diameter. Plenty on eBay.
Lol, I feel your pain. I have been looking for one as well for a while. I finally got one. Unfortunately only one. Sorry.
Very hard to find in that size. I was going to get a 285/75/16. Similar overall size and a lot easier to find.
so is the 285 75 r16 passable or will it wreck my diffs?
it's about 1mm different (bigger), so no it won't wreck them. presumably you're just planning on using it as an emergency spare rather than as part of a proper rotation?
Ey mate iv got a 33" tyre little bit of thread lift
Great for a spare 0411151853
Call or text me
Yeah I'll just be rotating the 4,
5th will be just in case
If you are concerned about your diffs then it will just be a slightly longer tyre change. Putting the slightly different sized one on the front without the hubs locked in you wont ever see an issue.
Hey guys I'm after a dual battery tray for a gq with td42 if anyone has let me know
Many thanks Rusty for sending the clips, i got them a few days back, 1st chance I have had to get on this site
Found not needed now
Found not needed
I need the connectors and a bit of the loom from a GU combination (headlights blinkers wipers ect) switch for my conversion. Any one wrecking a GU that has these surplus to your needs can you give me a PM.
urgently needed one of these tyres, good to new condition, PM me
Hi Warnie,
I am probably about to start breaking up my 94 GQ to sell, except for busted td42 diesel engine unfortunately.
Let me know if you still want anything?
I have one if you are still looking. i am in Brisbane.
Hi Mugsy,
I have a Mike Vine turbo from a GQ td42 if you are still after one.
Hi All,
I'm after a cargo barrier for our 2003 Nissan Patrol. It needs to go behind the second row of seats and allow for three anchor points (for child car seats). Does anyone have a second hand cargo barrier or can point me in the right direction for purchase/installation?
Thank you kindly.
Cheers,
Nic
Gday Nic, always a good idea to pop into the intros section before asking for help, start up a thread and let us know a bit about you, you rig and where your from. Something that's asked of all new members.
No biggy.......... anyway you be hard pressed to find one with holes for three anchor points. Patrols only have two anchor anchor points behind the second row. Have you tried gumtree for your local area? Or ebay.
Edit......... I found mine through gumtree, local car hire company had a few for sale and grabbed one for $30........ great condition.
Most I've seen advertised are around to 150 mark
Hi. I am looking for the removable panel bit in the rear (missing bit in photo)
should be fine to post
also after the rear dickie seat, the GQII one (cloth with headrests from an RX)
Sydney and newcastle area
Thanks,
Chris.
anyone got a good steel winch bull bar they want to sell,preferbally in south australia..thankyou..please send pm..
Pm sent pete
Sent from a device which doesn't always agree with my thumbs...
Gee I love this Forum
Hi mate,
Do you use facebook? There is someone wrecking a td4.2 at the moment in Sydney that might have that plastic cover your chasing
https://www.facebook.com/groups/6206406015/
Look for posts from "ThaShorty Monty"
Todd
thanks, i'll check it out
gday , I'm new here . I have a mk wagon cut down to a dual cab ute . I'm looking for a long range tank , water tank and a winch bar please
Busy weekend for the Forum Mark with the meet up and all. I'm sure the MQ/MK boys will be along soon to help you out
