Awesome mate. Huge upgrade.
Huge upgrade, I HAVE BRAKES!!!
Gu diffs and braced, they don't stick out too much and I may get away with it, did I mention I have brakes!!http://www.nissanpatrol.com.au/forum...2017/10/27.jpg
http://www.nissanpatrol.com.au/forum...2017/10/28.jpg
Oh what that was quick ! Nice one . . . SHINEY BITS ☺ . . .
Forgot to mention, the silver top is back!!!!!http://www.nissanpatrol.com.au/forum...2017/10/29.jpg
We all know what it really is though.
Probably should do a better pic, the extra 20mm does make a difference.http://www.nissanpatrol.com.au/forum...2017/10/30.jpg
Brakes rock!!! Best part about the upgrade I reckon. Beast.
Awesome stuff.. looks good.
I see you can buy Neg 44 rims also - I think @matfew has these on his rig? If I decide to go the 35" route these are probably going to be my choise as the rims sit way inside the panel, and since mine is not a 'twisty sister machine', these will work well.
Around 90-100mm
Not the most accurate way of measuring but should be close enough to work it out. http://www.nissanpatrol.com.au/forum...2017/10/33.jpg
Come on @AB go do the same, we need to know.
Feels a lot different to drive now with the GU diffs that's for sure, feels a bit heavier.
Turning circle might be a bit less too, need to confirm that with more driving, would they have to put stops in with this mod?
The stops should be all there mate just like on the gq items. It will feel different due to geometry being different between gq and gu diffs. The heaviness you feel is a slower turn in but once turned will fee better. Apart from the width there is quite a bit of difference in king pin inclination
Thanks Matty, wasn't sure if it was the old placebo effect with geometry but it just felt like the car was wider and steering was all new. I know it's only 20mm each side but a whole new game to get used to.
What about steering box is that a GU one now? Might change steering feel too. I know after getting my new steering box felt different first time i drive it for some reason. It's still a GQ one but felt like more turns lock to lock? . .
Yep GU box as well.
