Nah, not at home. Could cut most of it out with a grinder and get a die grinder bit from work and put it in a drill to clean it up.
Since I took the leap from the Dremel to the 240V die grinder, a whole new world of opportunity and pain has opened up. I am yet to really master the stability of the bit as have bent 4 burrs to date - into the bin they go. Where I am finding it invaluable is opening up clearance holes for bolts.
Stupid question....
Will a air powered die grinder work off a portable tyre air compressor??
No, they use too much air. You need a compressor and large tank or a really high flow compressor. A few of the guys on here have battery units, I know @MB has the Milwaukee brand, I bought the 240V Makita, and am very happy with it. What would have been good is a speed control pot on the grinder as mine is a single speed - bloody fast all the time.
Looks like you have about 15 to 20 mm of fairlead overhanging either side of the plate you welded to the back of the bullbar. Machine or grind the rear of these 15 to 20mm sections back like you said by 3 mm. Your fairlead is bearing bugger all load, its only guiding your rope.
The fairlead only sees zero load when the rope is sliding straight over it. Any angular pull into the winch outs load on the fairlead. Its a sliding load, so decreased by the co-eff of friction, but it is not potentially next to nothing. The fairlead needs to be supported or it may bend - simple reactions taking place.
Hit it with a grinder this afternoon, will tidy it up with the die grinder at work.
http://www.nissanpatrol.com.au/forum...2020/10/34.jpg
Question regarding getting the rope on the drum.
Took off the old cable and it looks like the small bolt that attached to the drum was broken. Do I need to attach the new rope the same way? I read that some just wrap it tightly. I'm going to put some tape as a marker about 2 metres before the end.http://www.nissanpatrol.com.au/forum...2020/10/47.jpg
If you can use the original mounting bolt, just do that. Alternately @MudRunnerTD, @Rossco, @NB have all used different knots and hillbilly chants i believe on their ropes with success.
