Thanks ET. I didn't make it clear it is for the front of my DX to take a standard tongue or winch cradle. I will check out XLR8 when next in Perth.
FYI ....
Many, many years ago in NSW it was legal to tow a vehicle ( with transit insurance ) with a "straight bar". A standard tow coupling one end with safety chains, a solid or heavy walled tube, & chains the other end, with a driver inside, for a short distance at low speed to a repair facility. I part owned a panel shop at the time and we used to tow them from our storage facility to the shop. About 2klms away. The towed vehicle also had to have a sign saying "under tow", a working hand brake and brake lights, or portable ones fitted. Times have long changed. Illegal now because of insurance requirements.
But, it is legal in NSW with the "right" gear like below, am I right?
http://www.nissanpatrol.com.au/forum...5&d=1506050614
http://www.nissanpatrol.com.au/forum...using-a-Patrol
Bazzaboy is talking straight bars and chains as the attachment device.
I don't know anywhere that config is legal these days.
Correctly set up A frames and assoc variations or manuf are 'generally' OK as they use either 3 points or rigid attachment IE not chains as a primary attachment.
I say generally as some states have weird local variations to their regs still but AFAIK Hitch N Go etc etc are OK but must be professionally installed and certified (at least in some states
the original posts asks legal or not so i suppose you could tow it with a shoe lace really..
I'm confident in saying that the method I described is no longer legal anywhere in OZ today. I also could be wrong, but I was under the impression that all the tow hitch configurations used behind motorhomes/RV's, all require welded or bolted attachment points on the vehicle being towed.
Yeah, in the OP I wasn't paying much attention to legality of it, but rather the technical possibility of it.
I am interested in laws each state has enacted with regards to towing a vehicle using a vehicle above techniques though.
So far, as far as I understand, there has to be a driver in the vehicle under tow unless there is setup to apply brakes and indicators etc in sync with the towing vehicle.
