We have Central Heating (Gas) and I have always hated heating the Bedrooms as when you go to Bed it only takes 30 seconds and you are warm.
I have blocked off the Register in our Bedroom.
That's similar to what I'm installing today sometime except I got all the bits separately as the cost is a lot cheaper and I scored a fair bit for free.
AB needs to run his under the house so he's got the dilemma of getting hot air from the ground level....bit tricky but might be possible
Let me know if it makes a difference Kris, would be worth doing if it works. Would of helped if i read Andy' post properly, sorry AB that link won't help you.
Extract from
http://www.universalfans.com.au/Heat...0Transfer.html
A typical system would be installed in the ceiling space and would consist of a vent above the heat source (such as a fire heater or similar), an in-line fan, ducting and a vent on the ceiling of the room the warm air is going to. Other possibilities include wall fans (for adjacent rooms) and running ducting under floor, false ceilings, walls, etc.
Well, the job is done. About 3 hrs and that's going to the hardware shop as well. The bloody house is bigger then I thought.
Now we wait for the results. Will let yous know later on today. Priorities first, of to the bottlo for some rum!!!
