MudRunnerTD
^^^^^^^ What this guy Said! ^^^^^^^
100%
Especially if you intend to run polyairs or something in the rear for touring? they are your adjustment and all that you will need IMO. The Front load will Not Change Ever once you have it set up with your bar and winch in place.
Chat with Matt from ProDiesel. I assume the Fox have the variable valving in them like the OME. Infinitely Variable. On that basis the OME will make micro changes to valving on each and even compression to account for the presented weight, speed of each movement. You will find the Fox will be the same. Your, the Operator, User, will never be able to tune your shocks that well.
Initial appropriate core Valving is the key. Provide your front and rear weights to the Shock provider and they should be able to provide you the right setup.
