chrismawn
Just had mine do the same thing..
Mechanic did following:
got error codes 76 - Fuel quantity solenoid valve signal improbable. 73 - pump communications line open circuit/short circuit.
Carried out a pump PSG scan. no pump codes were found.
Fuel filter replaced as slightly dirty.
Checked fuel tank and found black oil contamination throughout the main rear tank.
So mechanic advises to remove and clean the tanks then fit a new pump.
Looking at over $6k all up
Not sure I want to plow another $6k into a 2000 patrol..
