Same here, one thing at a time lol
Can I ask what normal retail is? I did enquire a while back but forget.
When do you need to know by?
Yeh sweet. Ill see how this engine swap goes. I was only talking about a pair of lockers yesterday so im keen. Will let you know after the weekend.
How much do you need upfront for the buy and when would the rest be required?
Just a heads up, found this online. Not sure if the issue has been rectified:
Quote..
"I ordered the replacement carrier bearings yesterday.
Stripped it down today and what do you know, "STANDARD BEARINGS WILL NOT FIT"
The original carrier has 45mm shaft diameter and the Eaton has a 50mm.
In the instructions, it does mention that this may be the case for some earlier Toyota diffs, but nothing about Nissans.
I think I will give Mark from Harrop a call and let him know of the situation so he can change the instructions."
Stropp, . did this happen or did it fall over?
Our local Opposite Lock give 10% discount on purchase & installation to local 4wd club members. A front locker is on the cards sometime in the next 12 months. If anyone can better that offer I’ll be interested.
