Ok, been away from here a few days now. Hence no replies from me...
Car is booked at a mechanic next week, so he will be running it on a dyno for a bit and see what's happening. I'm bloody happy but pissed off at the same time. I'm happy cause, the car has been running flawlessly last 4-5 days. It's been a rocket! But I'm pissed off that it's been "good", when I took it to the mechanic. It's like going to a dentist with a toothache, and on the way there it completely goes away like nothing happened. It s**** me!
While the car has been running fine lately, it has a different exhaust tone to it. It's like the tone changes when you open and close the needle valve (vanes) of the turbo. It just sounds different, and somewhat has a deeper tone to it? When last Mudski helped me set the valves up, he looked for a specific exhaust note for a rough needle setting. So, some pondering may suggest it's got something to do with the vaccum system slipping? Because the exhaust tone changed when the actually started behaving better ?
Was also talking to the mechanic , about gutting the vaccum system completely, and go for the wastegate setup, as well as a fully tuned chip that he does. He reckons it blows anything else out of the water and the CRD's respons really well. And this bloke knows what hes talking about. So will see how that goes... Obviously all pending what and if he finds with my intermittent power.
@Rumcajs
A lot of valid points there mate.
To answer your turbo question... Something is definitely going on inside the snail. Rattly kind of noise. It is in perfect sync with the turbo spool up/whistle. Very evident when you listen to it through the snorkle. No matter at what setting of the vanes, or vaccum completely disconnected, it makes this sound as it spools up. Once again the mechanic whos seeing it next week will suss it out, but HE personally thinks turbo is fine, even with the noise, since it is after all producing good power sometimes.
Watch this space.
