Seems like its not in the remote itself but in the wiring.
good to see your nearly on top of it.
IT'S an aftermarket unit with GPS,antenna is original I think and works ok,timer has been in for about 1 month,but problem was there before fitting (maybe not as bad though ? )
Try shutting down the engine manually (without using the shut down timer) with the radio on does the remote work?
If it doesn't, try fitting a blocking diode on the accessory feed to the head unit.
Tried that,and won't lock until radio off / antenna down
Ok,I picked up some diodes from jaycar today,so I put one in the power wire from ignition to the stereo?
Yep, the one that has power when the ignition key is turned on.
Then keep your fingers crossed and hope it fixes the problem.
