thanks again Nic for taking this on - it is pretty impressive
thanks guys very helpful:)
Thanks, thought provoking and informative.
What about explanining basic 3 to 1 adavantages, or about spliting your load , instead of pulling 1 ton why not only pull 1/2 ton
If you go back to the first page and have another look you will find the answers are there, also the top of the second page posted by EvilTwin also addresses mechanical advantage in basic maths.
Here is a couple of exerts
Snip
Hey Ben i hope the posts above clarify and fill the gaps you were trying to address. All good mate and i appreciate this thread getting bumped as often as you like.
Stay safe this Easter.
Cheers MR
Wow so wot winch systems and gear would you recommend?
Ok yes so all that stuff about degreases is good, some basic load sharing should be placed in hear for example if I was to pull a load that was 100kg and used a simple 3 to 1 I would be only pulling 1/3 of the load there for the load on my gear would only be a 1/3
I do not mean to be backward, I do understand what you have posted before, but I cannot stress how important it is to fully explain your advantages in say a 3 to 1. A lot of people just don’t understand, I do not know how to post diagrams to explain this but I was hopping you could. Just remember there are a lot more than just your basic 3 to 1, these things need to be illustrated so people can fully understand how they work.
I appreciate your input Ben, i have tried to address the 3:1 ratio and the use of a Snatch Block in the post above at the start of the second Snip.
I Highly Recommend that everyone clicks on the link provided by EvilTwin and scroll down to about page 6 where it starts to get really interesting. There are some great pics on page 8
Check it out here Power of the Snatch Block
