Re: Cant get auto transmission in 89 GQ auto to go into diagnostic mode.
Quote:
ckh
manual it say if the power light stay on and doesnt go though the test its either Inhibitor switch, power shift switch, kick down switch idle switch or the A/T controler is damaged.
1. Inhibitor switch must be working as I can only start the car when in park or neutral.
2. power shift switch is working as when triving if I hit the power switch, it drops down to 3rd, when I turn switch of it will go into 4th and then converter lockup if doing over 85
3 kick down switch is working as if I press accelerator hard it unlocks converter and kicks down a gear, or if driving slowly will drop down a gear, if going really slow and hit the pedal, it kicks down and the power light comes on.
4 idle switch dont know how to check this one
5. A/T controler is damaged. cant test this either as dont have a spare A/T controler at the moment but may be aquiring on in a few weeks.
ckh
TPS is fine, kick down works fine, power button works fine, just cant get into diagnostic mode
Diagnostic mode is ment to tell you what's wrong with the auto box. By having the power light stay on its trying to tell you that one of the above things isn't right. So that's a diagnosis isn't it?
You're expecting it to show something different than what it's showing you?
Another thing that got mentioned to me is to clean the pins/plug on the tcu.(in the passenger foot well on the door side). It made no difference to me but worth a shot
FanTapstic!
If it was a broken wire would the problem come and go (ie engage/disengage)? Or would it just never lock up?
FanTapstic!
Yeah that's what I mean, there's something making it unlock but if it was a broken wire it would probably be a constant thing. Not saying it's not a broken wire, just that it's more likely something else.
As I've said above, my diagnostic thing was doing the exact same as yours.
I wouldn't be too concerned with "getting it into diagnostic mode". I think it is diagnosing the problem as the books clearly state that a continuous light means those things you've mentioned above. Isn't that the diagnosis??
Anyway I would start checking all of the suggestions people have made.
TPS
Fuses
Loose or dirty plugs
Faulty power/overdrive button
Tcu plug condition
Fluid condition, type and level
TC condition
Temp sensors
Speed sensor
FanTapstic!
The temp sensor may have been incorrectly fitted or damaged when the box was out
FanTapstic!
