Hiya MM...
I drive mine exactly the opposite. I get it on boost ASAP by taking it out to 3300 to 3600 thru the gears so the revs do not drop below about 2200 and boost holds up at 16 to 18 PSI until I get into 4th/5th depending on spped limit.
Now had the vehicle for 80,000 K's and over that period it has averaged almost exactly 12.5 LPH.
When touring with the Camper the vehicle would be over GVM and the camper maybe 1100 Kg but I do sit around 95 KPH where the fuel flow on the scangauge is the sweetest unless there is line haul trucks catching up to me in which case I sit on 100 till I can get over and let them past.
Totally agree about losing the CC on the hilly stuff esp in a manual. A human who is looking after fuel and engine load rather than launching over the top at max noise will always outdrive CC in the hills. Us humans can also take much better advantage of the ECU fuel cut. Again a Scangauge (or ECUtalk) proves that every time or at least mine does.
Bottom line tho... I don't know why it is but some trucks are thirsty and some aren't and there doesn't seem to be a thing you can do about it. I have a 2012 Navara king cab 4cyl in the work fleet that will not get less than 15LPH no matter what. Usually up in the 17 to 18's...everyone hates the POS.
