LED lights are polarity sensative. Won't work back to front nor damage it. Did you check the positive and negative? One place to look at for something wrong.
I have finally fixed the grinding noise coming from the front left when braking and accelerating. I undid all of the body mounts and slipped some rubber shims in them as a stop gap measure until funds are available for new mounts. It has worked a treat.
Finally got a bit of low range 4WDing done.
Went to the local 4WD open day, meetup with Cuppa and cgm. Did a couple of loops around the track and then tackled the two hour hard trip through the local forest. Mud, dust, ruts, cambers, steep ascents and descents, all in all a good test and with great guidance from the members.
Enjoyed the day and nice to get the car out doing what it was built for, never missed a beat and preformed flawlessly (as expected).
I gave mine an Enema, 8 quarts of 15W40 and a new filter then a 4 hour Battery Charge and a big hug.
It seems to have enjoyed it.
I removed the engine today.
It appears I broke the guts out of my flywheel..
Mmmmm, interesting.
Someone else here did that. Or was it to the flex plate?
Changed the front diff oil and gave all the intake piping a once over.
Changed my 35's back to the 33's so I could get a wheel alignment, my tyre mans machine doesn't have arms big enough for the 35's :(
