My old UglyStick does that too...lol
I have 12....They are 2m long.
I know this sounds dodgy but if Winnie can use his conduit (which will be 100% fine) you and I can use 3 and 3 each gaffa tapped together to create a 3-4m high pole and I can promise that is ample mate. These rods are solid 8mm high density plastic and they will be fine...
I will bet my left one that this set up will be less whippy then a proper manufactured set up.
Ill make a set up tomoz as above Dazz and let you know just in case...lol
Wow the dodgey brothers thought you where going
to check out the ones at the show
