Yep Stauns maybe slower (but then again probanly no slower that having to go round and deflate each tyre one by one) and a pain in the arse to initially set up, but once done, stick em on and let them do their work......
I dont use mine any more. Found the springs stuck so deflation pressures were inconsistent. Then sometimes i want 18psi and other times 25psi so had 2 set at 18 and 2 set at 25 and it took ages to deflate using only two of them. The Currie deflator, while more work, at least achieves consistent pressures and whatever pressure you want.
G`day Guys
I use the end off an old hand pump or foot pump ( the one with the lever that folds down and pushes on the valve) these hold the valve open and it takes very little time to drop pressures.
I must say that I was the last to leave the camp at the meet up and did a walk around and the place was spick and span,(didn`t even find any chunder)Well done guys and gals.
http://www.nissanpatrol.com.au/forum...016/09/142.jpghttp://www.nissanpatrol.com.au/forum...016/09/143.jpg found this on the way home...i think the town is Brookton...
Ah fuck...knew its started with a --'b
And now you know why they didn't let me find the campsite
