Well it wasn't today but on the weekend I fitted a 3" zorst to the troll. Also cleaned out my Dawes valve as I don't have a catch can yet. Now I'm resetting up the needle and Dawes valves.
I bought a nutsert kit today to make under bonnet modifications so much easier and decided its first use would be to assist after I ripped out all the dodgy spotlight wiring that the previous owner had either installed or worse paid for. The switch wire join was just wrapped and taped, no solder.
I made up a little bracket and mounted two relay plugs for the spotlights and horn relays. In the past I've always just used spade terminals on relays but today is the beginning of a new ease of access and replacement era. (and it was a good opportunity to use the nutsert gun)
http://i31.photobucket.com/albums/c3...09_1909401.jpg
I'll have a look when I get home. Had a look at a few cheaper kits but decided to go for a better quality one that will handle 6mm steel nutserts
Its Marson brand and cost $145 which includes a selection of M4, M5 and M6 steel nut. I was looking at a cheaper brand for $99 and it was only rated for M6 aluminum nuts and didn't come with any so the extra $46 was well worth it.
http://i31.photobucket.com/albums/c3...010_100106.jpg
http://i31.photobucket.com/albums/c3...010_100116.jpg
looks great mate and thanks for the info on the nutsert set, will look into one as well.
