Yes but I did the lights mod to make them all work.
I found that I used the tow plug wiring for the lights and the tow plug has no power.
I'm sorry my mistake :biggrin:, I'll put some better ones up in my build a bit latter, but here's a couple of teasers
All pulled apart
http://i1083.photobucket.com/albums/...psoy580ww5.jpg
Winch sitting in there with lights inside bullbar so you can see what the drum is doing of a night time
http://i1083.photobucket.com/albums/...pshrkgn2j8.jpg
A view from on top looking straight down. I mounted the control box on just above the winch, you can see my 2 little led number plate lights on each end of the bracket I made just above the winch (above each end of the winch)
http://i1083.photobucket.com/albums/...psynur5lsq.jpg
And finally from the front with some lights on so you can see where the rope going, besides onto the winch
http://i1083.photobucket.com/albums/...pst79yt86y.jpg
I'll get some of the parkers later.
Cleaned the MAF and changed the air filter, now I'm charging my AUX to see if its still OK .
going away on the weekend and really need the AUX working,
saw the battery guy this morning and he has one ready to put in if I need it.
Also got the radio going again in my camper, don't ask,
@ mego I'd first check fuse then check plug on the back for squashed wires.
Had any work done recently like a new rear bar Ta DA
Late edit;;;; pretty sure my AUX battery is dead, bummer, Problem is I don't drive long enough to give the battery a decent charge
I'll leave the solar panel on it for a while longer and see how it goes,
Trailer/camper battery is 13v plus AUX is 12.75v could be better IMO
Update battery was US so purchased another 115 AH Tojan.
Bloody heavy, cost me $300 with a RRP of $450 so sort of happy.
I'll keep the water kit off the last battery for this one, last one lasted 5 years
Just shite myself ,just finished packing and move the camper and Patrol out the front and noticed fresh engine oil on the ground.
oil all over the front diff and steering damper. what the????
Phew turns out it was just the Catch can, that's the price I pay for not doing visual checks cause I cant bend.
will now get someone to look at it every 3 weeks or so. big relief
3D how is the back going since the op mate ??
recieved my slimline weather shields and marine travel buddy, will fit them tonight :) put my old smaller travel buddy on fb and sold it 5 mins later :) :)
Fitted the new bigger travel buddy but have since moved it onto an angle for easier access.
Attachment 49896
Packed it up and came home after 2 weeks at Fraser
Attachment 49897Attachment 49898
