Rumcajs
Where do I start?
The finish is absolute rubbish, like being build by 1st year apprentice. Out of shape, bent, incorrect or outright dodgy hardware supplied, like you need M14 bolts they supply M12, 5/8 bolts have M20 flat washers, 8 mm holes drilled for ally checker plate didn't get holes right so they used M6 bolts with M8 flat washers instead. WTF!
Even the castle nuts for carrier swing arms are out of shape, had to use fencing wire instead of split pins...
Locking pin is missing adjusting nut, pivot is welded crooked so the arm won't align with the locking hole....
Welding spatter powder coated in no worries. The worse think is that bar just wouldn't fit without enlarging the mounting holes way too large so it starts to affect the tensile strength of the brackets.
Those tiny flat washer they supplied bent like banana when just standard ratchet was used, I had to manufacture new washers/spacers out of 10 mm steel plate as the M14x1.5 bolts go all the way to 200 Nm.
Utter Taiwanese/Chinese rubbish.
Keep clear of those dodgy crunts.
Regards
