Mudski has 30 psi mine has 26 psi basically you need 10psi at 100 ks on a flat hwy
then use your needle valve to adjust the spool up rate, .
Normally at idle with the NV closed you slowly open it till the atuator arm falls away on the turbo at that point nip up the NV.
BTW where have you put the EGT bung most have it 150mm post turbo
Std boost is about 15 psi but if you can squeeze abit more without doing any harm why not, again its only a three litre
Btw I think my temps are higher than normal as the egt bung is very close to the turbo
you can just see the bung in this pic way too close imo
