A piece of 25mm square tube down that hole will hold that nut from memory.
Thanks, there is already a light sheetmetal retainer over the nut. i am going to take your advice from previous and open the hole up a bit so i can get to the nut retainer. I may be able t smash the retainer off and simply put the rattle gun it like the others.
Now regards lifting the body itself, how many jacks, where are they placed?
One jack and a long piece of wood. Pretty sure we did that 2 or 3 times on either side. That's what I did when I removed my body lift.
OK, 25mm body lift in, took 5 hours start to finish. Not difficult, just need to think it thru. ARB side rails are sitting on the factory flares but does not look out of place. Drivers passenger door feels tight to close, probably a bit of distortion going on from the jack, not a problem, just a note. The hardest ones to replace were the two rear mounts and the trickiest were the two front mounts due to congestion between radiator and grill. I used two bottle jacks and a block of wood. I blew up my rattle gun yesterday, so things started out a bit tiresome until I converted the battery drill with some modified tools to act like a rattle gun, then away it all sailed. I still need to cut a small section out of the floor behind the transfer case selector as can't get low range at the moment - job for tomorrow, Also lift might get me the room to modify the second fuel tank filler piping as well.
Made the adjustment to the floorpan, and rubber boot for the transfer case lever, took 2 hours to get all the 'stuff' screwed to the floor and trans tunnel so I could get the carpet up high enough. Was good to understand how the transfer case position detent rack worked - never really thought about it.
http://www.nissanpatrol.com.au/forum...019/01/154.jpg
Once that slot is engaged I can't see it coming out in a hurry, really good to see how 'positive' it is. A mate had a BJ47 shorty and he knocked that out of transfer case into neutral and enged up a roll over.
