Bigrig
I'd be going an aggressive all terrain and not a mud tyre - yes, you are hitting dirt and mud etc when you get there, but meanwhile at the batcave, you are traversing thousands of kilometres of bitumen - mud tyres also equal noise and additional fuel consumption ... Warnie mentioned a couple of brands below - I have the Mickey Thompson ATZ (all terrain) 4 rib pattern (the 4 is important as thy have a 5 rib pattern also). The 4 rib is somewhere between standard all terrains and mud tyres and they perform exceptionally well on the road, wet or dry (my wife has Cooper STT mud tyres on her Rubicon, and they are like ice skates on the road in the wet). The 4 rib is an aggressive enough pattern to tackle mud etc, but work well on gravel, sand and most importantly, bitumen!! Have a look in the "Clubs and Events" and "Trips and Treks" section for some videos of what we do on the QLD trips and you'll see a range of vehicles and tyres in action - if you intend on going more extreme than that, then go for mud tyres, if not, stick with 33" all terrains!! 35's will throw out your gearing and your speedo too much and you just don't need them (apart from also gaining the attention of the boys in blue!!).
