Mine came from http://www.ebay.com/usr/carpartsinno...p2047675.l2559
$99 us plus $23 us delivery about $160 odd our money.
Photos of what I did drivers side in working out the tang spacing , this did not work for left side I had to redrill the pivot hole 5mm further back .
At some stage you will need to remove door skin because there is a lot of checking involved , angle down you need on 100x50 you need to check it's not much on mine , I should have done the wiring and connected it up when I was testing for fit because although it all seemed ok when it was all welded up and painted I couldn't adjust the left mirror enough to see close to the car .
Attachment 71735Attachment 71736Attachment 71737
Sorry for all the photos just trying to give you as much info as I can to make it easier to work out .
